Starting your tractor
   / Starting your tractor #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I tried something on my new JD 4010 that others of you may want to try, to learn more about how and when the glow plugs work. I've read some potentially misleading information herein.
Here's what I did this afternoon:
I connected a jumper wire to one of my glow plugs and then connected it to a test light and then grounded the test light.
I turned the key switch to "on". No light.
I then turned the key towards start but not turning on the starter. Test light came on. Around 7 seconds or so later, I heard a low "click" of the solenoid, and the light went out.
I then turned the key switch to full start. The engine started immediately, as opposed to yesterday when I had to crank it a bit, accompanied by lots of white smoke on ignition because I didn't know about holding the key inbetween the "on" and "full start" positions to get the glow plugs to work.
I may do this every time in cold weather, just to make sure I'm turning the key to the right location and listen for the solenoid click to get used to it. Why oh why did JD not put a glow plug light on the dash board like Mercedes Benzes have had for years? (The Benz light comes on when you turn the key "on". When it goes out, THEN you turn it to "start'.)
For my jumper wire, it's one with alligator clips on both ends. I'm just leaving it clipped to the one glow plug and wrap/tie the other end around the air cleaner horn. Each alligator clip is covered with rubber coating; so there's little danger in it shorting out if I don't connect the test light to it.
Ralph
   / Starting your tractor #2
My 1998 Kubota B2400 has a detent just past the "On" position that lights up a glow plug symbol on the dash. When cold I hold it with the light on for an 8 to 10 count and it fires right up!!
   / Starting your tractor #3
Ralph,
Just put the range selector in gear or pull the PTO switch up, Then turn the key to start. The engine will not crank(due to the safety switches) but the plugs will ignite, 5 to 7 seconds is perfect. Then back to neutral or push the PTO switch back in.
It will start right up this way in cold weather.
Kenny
   / Starting your tractor #4
My ex-NH 1920 had the timed GP light. Can't rememebr if my 7610s does or not.. the dash is so sparse....
Soundguy
   / Starting your tractor #5
Ralph…
My Kubota L4200 has a light, like ‘Benzes’, on the interment panel, it is temp sensitive, during the summer it is on only a second or two… but during the winter it stays on five to ten seconds. KennyV.
This didn't light my test light:
The above must be a peculiarity. Doubt it will work on many tractors. Suspect there's a problem with the switches somewhere.
Glad to here that Kubota has the glow plug light right. Now, if they'd only redo their foot pedals.
Ralph
   / Starting your tractor #7
My Kubota L3000DT has a glow plug light that lights when you turn the start key in the opposite direction as you would to start the engine. A glow plug lamp lights on the instrument panel as long as you hold it in that position.
Depending on the cold and the length of time the block heater has been plugged in determines the length on time I allow the glow plugs to heat. Usually 5 to 8 seconds and the tractor fires right up.
I remember a Ford 1910 that I used a few times, it had a glow plug indicator that actually was a resistive heating element that glowed brighter the longer you held the switch in the heating position. The little bezel over the element was broken so it was hard to see the element get hot. I was told to put my thumb over the hole and hold the switch in the heating position until I had to move my thumb, worked every time. /forums/images/graemlins/laugh.gif
Randy
   / Starting your tractor #8
"My Kubota L3000DT has a glow plug light that lights when you turn the start key in the opposite direction "
The Class III NH Boomers w/ the D option have the light too.. but the key switch "glow position" is the first click in the direction of the full start position.
   / Starting your tractor #9
My Mahindra is similar, turn the key in the opposite direction & the glow plugs, as well as a indicator light come on. 5-10 seconds later, it starts instantly, no matter what the temperature is.
   / Starting your tractor #10
<font color="blue"> The Class III NH Boomers w/ the D option have the light too.. but the key switch "glow position" is the first click in the direction of the full start position.
</font>
You're absolutely right and unless it's cold winter weather I go straight to start without the use of the glow plugs at all. My Boomer has always started this way.
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
