etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,054
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
The thermostart in my Yanmar YM2310 is bad. The new one I put in failed right away, it heats up but won't flow fuel. And yeah, I have done all the tests, it's just bad. While waiting for the new one to arrive I have been using the tractor anyway but it is of course hard to start when it is 34 degrees out. Is this bad for the tractor aside from maybe working the starter too much?
I pull out the decompression knob, spin the engine, and don't let it go until the motor is spinning pretty fast. It takes maybe 15 to 20 seconds of cranking before the engine will stay running. The engine tries to start while cranking though. First off there is a little puff of white smoke, then it starts to turn black. When the engine finally keeps running it does belch out black smoke for a few seconds but then stops smoking and runs normally. It also clatters for a bit but it's just the usual clatter some diesels make when first started. The clatter just lasts for a second or two.
Thanks,
Eric
Thanks,
Eric
