I have TC-35D witch has a starting problem,when you turn the key switch it just click.Now on cool days it will start on hot days it won't,after it warms up you shut it off won't start even with a jump from a truck but if you put a battery charger on it will start.I have a rebuilt starter and a new battery pus I added some extra ground wire from frame to engine. I moved fuses around and check my safety switches.Not sure how to check the Ignition switch.Does anybody have this problem or the answer.
Colors
Colors
