Starting Problem
   / Starting Problem #1
justaswild
Grand Junction, CO
Mitsubishi MT372
Recently I purchased a 1980's? Mitsubishi mt372 2 cylinder, 15 hp diesel compact tractor. The only way we could get it to start was by jumping it with another vehicle and spraying WD40 in the intake. The previous owner assured me that it was the starter. So I took it home and put a new starter and battery on it. Still having the same issue. But now, after it runs for a while, and I shut it off, it will start back up. But if I let it sit for a few hours, it needs WD40 again. Something else that's strange is when I leave the key in the "on" position after it starts, It kind of sputters for a while. But if I turn the key to the off position, It revs right away without the sputtering. Also, with the key on. It will only rev to 2500 RPM. With the key Off, it will rev to 3000 RPMs. Glow plugs seem to be working. Any ideas?
   / Starting Problem #2
Sounds like your alternator is dragging. Key on activates the charging circuit.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
