Starting problem on L4740
   / Starting problem on L4740 #1
jaymak
Kubota L4740 HST
Need help so I can get my tractor back in the garage . . .
I was moving logs with pallet forks and cutting rounds with my chainsaw. I started and stopped the tractor several times to saw, move rounds, etc.
On the fifth or sixth time, the tractor would not start, and the intellipanel was acting flaky. It was making some clicking and buzzing noises.
So, I assumed the battery must have run down with the frequent starts, but no, it is measuring 12.5 volts. Still, I am charging the battery, and not having any luck. My charger is indicating the battery is 90% charged, but the symptoms remain. Flaky panel, flashing LCD, clicking/buzzing, and nothing when turning the key to start position.
Does anyone have a suggestion?
Thanks,
John
   / Starting problem on L4740 #2
First thing is to make sure the battery is good, Sounds like the battery is shorted out. A shorted out battery will show 12.5 voltage or even higher, but won't handle a load. "Remove it"and try a known good battery first.
   / Starting problem on L4740 #3
If you have a multimeter (I assume that's how you measured the battery voltage) I would have someone try starting the tractor while measuring to see how low the voltage drops when it's trying to turn the engine over. Just don't do it very often because low voltage is real hard on your starter.
Thanks I'll give that a try tonight and will update. Thanks guys.
I think you guys hit the nail on the head . . . the battery voltage drops from 13 to 6 when I turn the key to the run position (not even start). So, I'm betting a new battery will solve this problem . . . more to follow when I get a chance to pick one up. Hopefully the shock from moving logs around just knocked something loose inside he battery.
   / Starting problem on L4740 #6
You may want to consider a optima battery. They are shock resistant and they are sealed so they won't leak acid all over you tractor.
   / Starting problem on L4740 #7
Optima batteries made in the last two years are junk, since Johnson Controls bought them and did cost cutting resulting in enormous failure rates. Many others make AGM batteries with excellent reputations. Die Hard Platinum, East Penn Deka Intimidator, SuperStart Extreme AGM, etc.
   / Starting problem on L4740 #8
Your charger must not have a "start" mode where 100 amps or so is fed to the starter.
Not sure if it would work with a shorted battery.
Maybe if you took the battery out of the circuit and just used the "start" on the charger (if you have it).
   / Starting problem on L4740 #9
JCI has owned them for years. I think they even supply batteries to die hard. I know jci supplies the to walmart but some are exide too.
   / Starting problem on L4740 #10
I'm not sure what options are available given the limited space.
2008 Chevrolet Express 2500 Ambulance (A51692)
2008 Chevrolet...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Massey Ferguson 1745 (A50123)
Massey Ferguson...
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
