Starting problem on Kubota B7500
   / Starting problem on Kubota B7500 #1
PriceWOwens
Dallas, TX
Kubota B7500
My tractor was running fine. Then while trying to start if following day it would not start. The tractor was dead. The lights and all other electrical items were working and the battery was charged OK. I had the kill button all the way in as required and clutch was in (it is HSD). Turning the ignition switch did not even crank the starter at all. Any ideas as to what this problem is or how to fix it.
   / Starting problem on Kubota B7500 #2
It might be one of the safety switches. On my B7500 HSD, you need to be sitting on the seat, the speed control pedal needs to be in neutral position, the clutch pedal needs to be fully depressed, and the PTO level must be in the neutral position. The PTO lever is easy to bump out of neutral when mounting/dismounting the tractor.
   / Starting problem on Kubota B7500 #3
I have had this problem with my 2010 Kubota L4400. To get it started I have had to push the cruise control lever from neutral and then back to fully disengaged. This allowed me to start it but recently this seems to be interrmittent . I know this has something to do with the safety defaults, but it needs to be eliminated so that it will start without wickering it around.
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2020 KUBOTA RTV...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2021 KENWORTH T680 SLEEPER (A51222)
2021 KENWORTH T680...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Mini Forks (A50322)
Mini Forks (A50322)
