starting problem century 20 series
   / starting problem century 20 series #1
nightmare3z
Having trouble starting tractor. can hear a clicking noise , sounds lilke the key switch but doesn't spin the starter. One time we rocked the back wheel and then it spun over and started. Later same problem and can't get starter to spin. Help me trouble shoot if ya can . thanks
   / starting problem century 20 series #2
How long have you had or how old is the Century? Reason I'm asking is if it's new (or new to you), you might be falling prey to one or more safety start lockouts - shuttle in neutral, PTO off, & clutch all the way down. We had trouble realizing that if you don't press the clutch with the ball of your foot, you don't get it all the way down.
Other than something that simple, that's about all I know about Kukje starter systems. Afraid I don't know what the tire rocking means. Good luck!
   / starting problem century 20 series #3
Check the battery connections first.
Then to what caused the same symptom on my Century.
Check the ground connection from the battery to the frame. This is under the frame and after cleaning same on mine I had no further trouble.
Roy
   / starting problem century 20 series #4
Had same problem. When they come accross to pond the connections get coroded and if you clean them they are ok again.
problem fixed, safety switch on pto lever had shorted. wish mechanic had checked it first would have saved some labor. /forums/images/graemlins/blush.gif Thanks for the inputs
Set of AG R4 Wheels and Tires (A53472)
Set of AG R4...
INDUSTRIAL UNISAW TABLE SAW (A51248)
INDUSTRIAL UNISAW...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
