Starting Oil Pressure
   / Starting Oil Pressure #1
Anonymous Poster
Epic Contributor
Everyone says on a cold start to crank the engine until oil pressure is shown.(light goes out etc.) Well on my little 1300D I thought the sender was bad so I installed a gage. Although once stated the pressure is good (around 30 psi cold, 15 to 25 hot) It takes quite a few seconds after it starts to build pressure. With the starter motor cranking for 10 to 15 seconds no oil pressure will be notice. I would like know if this is normal, and if so just how long do you all run your starter to obtain pressure. Thanks
   / Starting Oil Pressure #2
As recommended in the manual, when cold I use the compression release on my Yanmars (engines crank very fast this way). I crank until the oil light goes out (usually 2-3 seconds), then push in the compression release and they fire up. So before the engines fire, I have oil pressure.
Jim
Thanks Jim for your comment. I to use the compression release and engine does turn fast, however only when engine is hot and shut down for a short period of time will the light go out/gage show pressure on cranking/startup. It seems like the oil drains off when left over night. I'm using a WIX oil fiter do you know if there is a check valve in the OEM oil filter to stop bleed off?
   / Starting Oil Pressure #4
Ron, I have a YM165D which has almost the same engine as your 1300. Yours sounds normal to me. I usually crank mine like that for about 5 or 10 seconds when cold to build pressure. Sometimes the light goes out and sometimes not. If not, I push in the compression release and start it anyway....but watching the oil light carefully. I expect it to go out within a few seconds of starting. For hot starts I just turn the key and go.
I forget what the low pressure switch is on that light, but I think it goes out at less than 5 psi. Yanmar never did seem to care as much about low pressure as they did about limiting the high pressure side. It is common for that motor to idle with 5 or less PSI. At very low idle the oil light will flicker. Not a problem....
There is a high pressure limiting valve within the motor block where the filter screws on. If it sticks open then the engine will not develop any oil pressure. Also, I think that there is an anti-drainback valve in the Yanmar oil filter. I assume that Wix has it too, but don't know as I only use the Yanmar ones. The drainback valve will not prevent what you are seeing at cold starts...again, yours sounds normal to me.
Thanks Roger for your comments
   / Starting Oil Pressure #6
I put an oil pressure guage on mine, crank it until pressure reaches over 20 lbs, release compression lever and it starts within 3-5 seconds.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
197711 (A51244)
197711 (A51244)
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
John Deere (A50322)
John Deere (A50322)
2009 IC...
43029 (A51691)
43029 (A51691)
