Cjm005
To summarize.. I bought tractor from original owner, and the wiring is a mess. I suppose the previous owner lost the key, because he tucked the ignition switch behind the dash and just hooked up a push button...
Prior to installing, the glow plugs, warning lights and everything else was not working. I installed the new ignition switch ($77) and everything is working again, with exception of starting. The PO disconnected all of the safety switches (clutch, PTO & neutral) so I'm trying to figure out which ones are "correctly" disconnected - the PTO safety switch is just disconnected and looped. For some reason I can't (yet) find the wires that connect to the clutch switch - the switch itself is destroyed beyond recognition.. I have wiring harness, just thought I would post up in case anyone has been through the same problem.
