Starting/Bleeding Fuel System Problem Solved
   / Starting/Bleeding Fuel System Problem Solved #1
threepiece
Bronze Member
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
I ran my 110 out of fuel the other day. According to the service manual the system is self bleeding so I thought I would simply add fuel and go. This was not the case. After refueling, the engine would start after a considerable amount of cranking and then for only a few seconds. I repeated this several times before I began to investigate. After checking for water and a few other things I noticed gas (presumably air) escaping when I loosened the spin on fuel filter. I'm not sure if it was pressure or vacuum. After retightening the filter the engine started and ran good.
I understand there are at least two fuel systems found on the 110's. As I understand one type does not use the spin on fuel filter.
I hope this helps someone.
Gosh I forgot to include 110 TLB in the title. I hope someone could add that for the benefit of others.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
2016 Nissan Titan XD SL 4x4 Pickup Truck (A51692)
2016 Nissan Titan...
