SalisburySenior
I have a 1983 Kubota M6950DT. I have just replaced the fuel filter and after a couple of seconds of running, the engine stopped. I've cranked the engine for some time and now have the battery charger recharging the battery. How long does it take to purge the air from the system? Is there some technique I should be doing other than cranking the engine? I have the factory manual, but it simply says to unscrew the bolt on top and replace the filter cartridge. No hints on how to purge the air from the system and get the tractor running again. I'd appreciate any help you may be able to provide.
