Starting a Ford 4400 (gas) for the first time in 3 years
   / Starting a Ford 4400 (gas) for the first time in 3 years #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
Maybe longer. It's a 1969 Ford which my father bought in 1975; it's been stored inside since then, and hasn't seen a lot of use in the last decade or so. About 4-5 years ago he advertised it for $4000, got all sorts of low ballers, one person offered 2K saying "it doesn't have rear remotes", so he parked it in the barn, pulled the battery and I don't believe that it's been moved since. I tried to get it going two years ago but my spare battery wasn't powerful enough, working with old gas in the barn cellar seemed a recipe for disaster, and I had nobody to help me get it outside so I bought my Kubota instead. My brother is in town so Saturday we're going to drag it outside where I'll drain the stale gas, clean the carb, put fresh gas and a new battery in it and see if I can get it going. Once it's running we'll figure out what to do with it; my brother thinks we'll sell it for 2K or so, but for that price I'll sell the 'Bota and run the Ford.
At any rate it'll be good to see the old girl outside in the light again... then my next project will be the new waterpump and carb rebuild on the TO35 so that I can get that up here.
   / Starting a Ford 4400 (gas) for the first time in 3 years #2
since it is gas pull the plugs and soak the cylinders with a oil and kerosene mix for couple of days then roll over slowly by hand careful of stuck valve, might want take valve cover off, drain the oil and inspect for water, drain radiator fill with plain water to start. Disconnect tank and change fuel filter run from a can and hose. Clean the carb remove and soak in some gas and gumout. Use starter check for spark, and roller over and put thumb on each plug hole check for compression is stuck valve open. Then assemble and use some starter fluid on it. Run for 45 minutes change oil and filter again. Then if it doesn't eat oil and smoke your OK.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
