saltbranch
- Joined
- Sep 29, 2009
- Messages
- 219
JD 4020 diesel, appearantly old enough for generator and converted to altenator. Its setup for 2 12 volt batteries, which I will get this weekend from ranch truck. I have drained about a cup of oil from the pan and checked dip stick....looks good, no discoloration or metal shavings. I am going to change fuel filters and use fresh fuel from a seperate tank. Where is the primer for the fuel pump? Where do you check the hydraulic and tranny/rearend fluid?( I'm more of a car guy..sorry if lingo is wrong).
The radiator is not available(yet), so I have to be quick in checking out the running motor once started. My first post on this tractor was
http://www.tractorbynet.com/forums/john-deere-owning-operating/154040-4020-frame-rails.html
Again thanks for any tips/advice
