Starter welder?
   / Starter welder? #1
Butch2112
MF 35
OK I haven't welded anything since I was an apprentice electrical worker a LONG time ago, Ans was wondering what a good and if possible an inexpensive welder would run me. Mostly I will use it around the house and some light farm type stuff. The only thing I ever used in the past was an old lincoln stick welder, Any suggestions?
   / Starter welder? #2
If you could find one of these on Craig's list, or you local penny saver. They are bulletproof, very nice smooth arc. :thumbsup:
   / Starter welder? #3
Unless you're going to be welding thin guage steel I would do like stated above. Find a Lincoln tombstone AC/DC stick welder or something similar.
   / Starter welder? #4
I agree, unless you plan to weld quite a bit of sheet metal, a used stick is the way to go! I have both, a 50+ year old Marquete 180 amp stick & a used 135 amp Lincoln wire welder for the sheet metal. ~~ grnspot110
   / Starter welder? #5
Actually, if you have some welding experience, no matter how long ago, you can use 5/64 rod and learn to weld sheet metal. I welded so much sheet metal with my old tombstone that I got to where I could weld it sometimes better than heavy stuff. It's just practice, practice, practice.
I had no money for a MIG welder in the old days, so I had to use what I had to work with. If you need to weld sheet metal and a tombstone is all you got, you will adapt.
   / Starter welder? #6
well.. if you don't want to spend alot.. then an old tombstone will do ya.. sometimes you get lucky and can find a dc machine.. but if noting else.. and old 225ac buzzbox will sure weld lots of metal together.
I use a hobart xl235ac at my farm. so far it's been an awesome machine and makes good welds.
soundguy
   / Starter welder? #7
Yes, my tombstone as AC only. I learned to weld with it. After learning to weld with an AC welder, when I got my hands on a DC welder with 7018 there was nothing holding me back.
   / Starter welder? #8
After 30 some years I still have my AC only tombstone and it still gets used A LOT...:thumbsup:
I also have a mig which I use when I need to weld thin material. But when I'm dealing with pipe fencing, etc. out comes the old red machine and in goes 6011 into the stinger.
Inexpensive, rugged and forgiving. Great beginner's machine.
You can't go wrong with a tombstone.
Good luck.
   / Starter welder? #9
yep.. I burn more 6011 rod than anything else.
if I need something to look exceptionally pretty.. Iusually burn a 6011 to make sure it's glued together, then burn a 6013 on top of it... :)
have access to a mig at work as well as a dc buzzbox.. but I like my hobart ac buzzbox at home. so far it's done anything I need it to do for stuff above 1/8 for sub 1/8 I have a lil 30/70a CH stick welder and some 5/64 and 1/16 rods...
soundguy
   / Starter welder? #10
If you could find one of these on Craig's list, or you local penny saver. They are bulletproof, very nice smooth..
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2020 Chevrolet Silverado Service Truck, VIN # 1GB4YSEY9LF325286 (A51572)
2020 Chevrolet...
20623 (A51691)
20623 (A51691)
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
Hand Truck (A52377)
Hand Truck (A52377)
