Starter Solenoid
   / Starter Solenoid #1
Ford851
Bronze Member
So. Bay Area, Ca.
Ford 851
Anyone know the Ford 851 4 post starter solenoid part number? What is the Napa equivalent part number? All I can find are the 8n or 9n part numbers. Are they the same as 800 series solenoids. Napa is closer and probably more reasonable. I know I've seen it posted somewhere, but my searches aren't turning up any good results.
This bring up the point, "how do you narrow a search"? Each time I put in a search line I get 2500 posts. Are searches done on the whole site or can you narrow them down to a single forum? What is the delimiter used for searches?
Best regards,
Ford851
   / Starter Solenoid #2
i don't know the part number but if sound guy or some of the vintage tractor experts see this they can help might send him pm good luck
   / Starter Solenoid #3
311007 is a ford 4 poster, 6v oe number
st541 is the napa #
   / Starter Solenoid #4
st541 is the napa #
   / Starter Solenoid
Thanks soundguy. If I am now running a 12 volt system shouldn't i be using a 12 volt solenoid to close the starter circuit? I think the two center posts are just a coil that when energized closes the contacts for the heavier battery/starter circuit. There must be some logic behind why a 6v solenoid is used. Bottom line: it works so use it:confused2:
Thanks,
Ford851
   / Starter Solenoid #6
they are a simply isolated base solenoid. the 2 small posts just conenct to the field coil.. energize them and the solenoid pulls in and connects the 2 larger contacts.
thus power from the key to one small post, and the safety starter button ( ground ) to the other small post.
the 6v solenoid works FINE on 12v.
if you want to get very particular about it, you can lookup the solenoid to a diesel 4 cyl ( 59-64 ), and it will have a 12v 4 post solenoid...
I've yet to ever change to a 12v solenoid.. :)
   / Starter Solenoid
Thanks sound guy,
Got it Really no need to change as you point out. Just curious. Too lazy to pull the specs.
Will be changing to 4 post when I install stuff to get back to original configuration.
See ya,
Ford851
   / Starter Solenoid #8
311006 is the oem #
ST542 napa echlin.. 12v
   / Starter Solenoid #10
Soundguy,
I have a 1958 Ford 861 D that's 12V and I need a solenoid. Checking NAPA there price for a ST542 is 31.00. Tractor Supply sells a 4 post solenoid for 12.99 but the part number is 311007FR for a 6V system. The specs on the solenoids appear to be the same, have you ever used a 6V solenoid from Tractor Supply for a 12V system?
2016 Ford F-150 Pickup Truck, VIN # 1FTEX1CG6GKF21612 (A44391)
2016 Ford F-150...
2014 WESTERN STAR 4900 TRI-AXLE (A45046)
2014 WESTERN STAR...
Gooseneck Trailer (A44391)
Gooseneck Trailer...
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
2019 HINO 268 26FT NON CDL BOX TRUCK (A43004)
2019 HINO 268 26FT...
2013 PETERBILT 389K OILFIELD BED TRUCK (A45046)
2013 PETERBILT...
