Starter removal on John Deere 3203
   / Starter removal on John Deere 3203 #1
Herman M
Kenton,TN
John Deere 3203 John Deere 2120
My tractor won't start, and I believe I've eliminated everything except a problem with the starter itself. I removed the 2(?) bolts holding it in place, and it doesn't want to budge. Do I get rough with it, or is something else holding it in place. It's in a pretty tight spot, and I may be overlooking something.
   / Starter removal on John Deere 3203 #2
Parts diagrams show just two bolts. Get rough
   / Starter removal on John Deere 3203 #3
How did you get to the point of condemning the starter? The starter relies on contact with the block to get it's ground path. Many tractors have rust build up and slowly there is no longer a good ground.
The fact that your starter is difficult to remove suggests a rust issue.
Buy a battery cable with eyes on each end. Clean up the area on the starter where a mounting bolt goes and then secure one end of the new cable.
Find where the battery negative cable is connected to the engine or frame. Remove and clean, then attach the other end of your new cable here.
See if your symptoms improve.
Dave M7040
   / Starter removal on John Deere 3203 #4
Might be rust from repetedly washing your tractor with hot water . Steam going in all places you do not want it or the problems it causes !
2239 (A51244)
2239 (A51244)
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2019 Bobcat E26 (A50120)
2019 Bobcat E26...
2019 FORD TRANSIT VAN (A52141)
2019 FORD TRANSIT...
Claas 340 Round Baler (A50774)
Claas 340 Round...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
