Starter problems
   / Starter problems #1
KatieL3710hst
Florida
Kabota L245DT / L3710hst
After changing hydraulic fluid in and filters it started up four or five times then sat for about 10 minutes then when I went to start it it would just click and the lights would go out I thought it was the battery so I got a new battery installed same problem so I don’t think it was the battery. Any advice would be very much appreciated
les
   / Starter problems #2
You need to check all battery connections, ideally do a voltage drop test accross the wires to see where the voltage is lost.
   / Starter problems #3
Especially look at the ground wire for the battery where it connects to the frame...it can look OK but still not making a good connection...
   / Starter problems #4
Either a bad (dirty) battery connection or cable connection or maybe even a bad cable. Mine does that when the terminals get dirty.
   / Starter problems #5
To quickly test either of the big cables, connect a regular jumper cable in parallel around it.
  • Good Post
Reactions: JWR
   / Starter problems #6
You can also use a DMM to check the impedance of your wiring. Especially your grounds.
   / Starter problems #7
Just went thru the same on a friend's L4740,after a new(2) starters it was a bad ground.
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
2020 KUBOTA RTV...
JLG 1255 Telehandler (A52128)
JLG 1255...
Behlen Country 3 pt Leveler (A50514)
Behlen Country 3...
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
