Starter not getting full voltage
   / Starter not getting full voltage #1
Liltote
1949 Ford 8n
Good afternoon all. I have a 1949 Ford 8n 6v. It is turning over slowly, when i test the starter, i have 6.35v on the battery side, and when i activate the starter i only get 4.3v on the starter side. Does anyone have any ideas on this? Thanks for your help.
   / Starter not getting full voltage #2
It could be a bad cell in the battery, check the voltage at the battery terminals when engaging the starter. If it drops, bad cell. If it stays at 6+v, check the connections at the terminals, starter connections, and solenoid, if separate, and ground. Take note of the cable condition as well; if the clamp has lots of corrosion and the plastic jacket has swelled near it, the corrosion has migrated down the cable and is causing lots of resistance.
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
Land Honor Quick Attach Skid Steer Plate (A50515)
Land Honor Quick...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
Land Honor Diesel Fuel Transfer Pump (A50515)
Land Honor Diesel...
