Ansam, how many wires are there? If your starter has the solenoid attached to it there should only be the real fat one that supplies battery power plus one probably with a spade connect that attaches to the solenoid to energize the solenoid when the key is turned to start. Sometimes there is also a smaller wire with a terminal with a large hole that connects to the solenoid on the same terminal as the battery power to supply voltage to other accessories.
