Starter issue?
   / Starter issue? #1
reprosser
Midlands of South Carolina
I have a Kubota L3240 - a few years old. Last week, I turned on the switch, the control panel flickered a little, and when I tried to crank - the system died. I turned off the key, turned it back on, and the panel flickered a couple times and died.
After sitting a few minutes, I tried again with no luck.
I have checked all the fuses and relays, changed the battery, tightened connections, but cannot seem to find the problem.
When the system shuts down, the voltage at the switch drops to about 4 volts. Voltage across battery terminals is 12.4 v. If I pull the fuse for the alternator, the voltage rises a couple volts, and if I pull the fuse to TM controller, the voltage rises a couple volts. If I wait for an hour or so, eventually the voltage at the switch will come back up to 12.2 volts, and after re-inserting all the fuses, the panel lights up when the switch is on - but if I try to crank, I hear the starter solenoid engage, and the system shuts down.
I removed the starter, and it seemed to work ok when connected outside of the tractor. I put the starter back on the tractor and manually shorted the solenoid, and the starter tried to turn over the engine, but only turned the fan about 1/2 way around. Voltage dropped back to around 4 volts.
I plan to replace the starter today, but if this does not fix it - I have no clue what to do next. I will have to get the dealer to come by, load it up and troubleshoot in the shop. Unfortunately, it is inside the tractor shed with the bush hog connected. Going to be a chore to get it out and on a trailer...
Any ideas for something else to check?
   / Starter issue? #2
Replacing the starter will have No effect...
You are dropping voltage somewhere... It 'could' be in the battery itself, or at any one of Many connections Including several grounding spots.
You can find this with a volt meter... You will have to have a fair Load on the system, All the lighting "may" be enough load to allow you to do a voltage drop test... KennyV
   / Starter issue?
OK. I guess it is just the load from switching on the starter that is making the problem more evident? Will spend more time with the volt meter...
   / Starter issue? #4
Double check both battery connectors, starter connector and go check both ground bolts for battery cable and engine ground make sure clean and tight bolts.. Also you may have battery tested to see if it has bad cells.
David Kb7uns
   / Starter issue?
I did replace the old battery with a new one as the first response. Had the same behavior as before.
Since I have been troubleshooting for 2 days, I probably need to recharge.
The fact that the voltage seems to creep back up makes it more challenging as well - as I am testing, not sure if something I did impacted the rise, or if it occurred on its own.
When replacing a fuse, I have seen the voltage drop, and then rise higher than before the fuse was removed.
   / Starter issue? #7
Sounds like a shorted out battery, it will show normal voltage until it is loaded up. Shorted out battery's are the biggest cause for replacing good starters. Shorted out battery's can't be jump started with a know good battery, only replaced.
   / Starter issue? #8
From your symptoms I would say you have a bad connection somewhere. The battery connections need to be both clean and tight. Lead terminals oxidize in air... if the terminals are gray they need to be cleaned before tightening. Check the ground side of the circuit by checking for voltage drop between the negative battery terminal of the battery and the engine block. Do the same between the positive battery terminal and the starter. You could have a bad ignition switch. check that you are not loosing voltage there.
With a little probing, you should be able to find the fault.
   / Starter issue? #9
I didn't see that you replaced battery, Guess I skipped that post.
   / Starter issue?
I will have the battery tested, and then start again on tracking down the voltage drop. I agree it seems to be a connection issue.
I will start by cleaning the <good> battery connections, connecting the batter terminals, and removing the fuses to start checking voltage. Since the battery GND is connected to the frame, and the starter is connected to the engine, I will check for stray voltage between frame and engine block.
Once I get good voltage to the starter, I want to see if I can manually turn over the engine. If I only have the starter connected, it should be able to turn over the engine - even if nothing else is connected? I know it won't start since the Key Stop relay will not be engaged. This should eliminate the starter, and the GND connection if it works.
Thanks for all the help and suggestions.
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
