Starter Fuse
   / Starter Fuse #1
Steve Brockhouse
John Deere 135
I have a John Deere LT 135.
Run well for 3 or four seasons. Now has 125 hours running time.
There is a 20 amp fuse in the wire between the battery and the starter relay.
I believe this simply supplies power to the relay which operates to connect the battery to the starter motor.
When I start the engine this fuse deals with the current just fine. I.e. the engine starts as expected.
The machine runs just fine for as long as I need to cut grass.
Sometime between when I start it and when I shut it off this fuse blows.
Next time I try to start this fuse has blown.
Where should I look to resolve this problem.
Thanks, Steve Brockhouse
   / Starter Fuse #2
sounds like it could be in the key switch....maybe bad contacts in the switch causing a short....
   / Starter Fuse
Good idea.
I'll give it a try.
Thanks, Steve.
   / Starter Fuse
I removed the connector and cleaned the terminal posts.
There was an indication of a few grass clipping and maybe a spidy web or two but nothing that looked as if it would cause a short.
Put it back together.
Problem appears to be cleared.
Whether it was something I did or whether the Deere Gods are smiling at me for having restarted the engine the required number of times this season I cannot tell::).
Maybe it was just tired fuses.
Anyway, I was able to start and stop it a number of times this aft.
Thanks for your input and help.
Steve Brockhouse
Let's hope it keeps going all summer.
Kubota RTV500 (A47384)
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
378811 (A51573)
378811 (A51573)
RoGator RG1100C (A55302)
RoGator RG1100C...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
1274 (A50490)
1274 (A50490)
