starter and battery problems
   / starter and battery problems #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
My 755 seems to be going threw batteries and starters all the sudden. The last 2 batteries have only lasted a year and my starter was rebuilt last fall. The starter all ready has a dead spot in it in less then a 100 hours of use. I don't have any problems starting the tractor so I know I am not getting it hot. What would cause this to start happening. I am going to talk to the dealer tomorrow about it but I would like to hear what you have to say also.
   / starter and battery problems #2
I would suggest checking the battery cables, the ground connections and the wires from the alternator. If you have low battery voltage it could cause the starter solenoid to stick. I am not saying that is it but I would make sure the electrial connection in the charging and starting system are in perfect shape.
   / starter and battery problems #3
I would check the voltage while running, if it is too high it can kill the batteries.
Most starting batteries will last for 5 years or more today.
Steve
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
(49) 2" X 3" X 27" TUBING (A54756)
(49) 2" X 3" X 27"...
