Start with the simple things - Ford 6000 now running fine
   / Start with the simple things - Ford 6000 now running fine #1
Aussiebushman
Jerrong, south of Oberon in NSW, Australia
Ford 6000
Had a constant problem with this 6 cylinder diesel beast constantly cutting out with air in the injector pump. Didn't matter how many times it was bled, it would not run for more than a few minutes. The biggest worry was what seemed to be diesel fuel running out the injector pump. Shock - horror at the potential cost and hassles of repair.
Degreased everything so I could maybe see where there could be a leak. The result was so simple - a hole in the fuel return line where it passed through a steel plate, but nowhere you could see before removing the side covers. The fuel was just running down the line until it pooled at the pump.
Cut the steel lines, replaced the flexible hose with fuel-grade rubber, protected it with some heavy spiral tube and refitted it. Tightened every junction I could find, bled it again.
Surprise, surprise - now runs perfectly! The moral of the story: don't do anything expensive until you have checked the simple things
   / Start with the simple things - Ford 6000 now running fine #3
Excellent troubleshooting, I am glad it was something simple.
   / Start with the simple things - Ford 6000 now running fine #4
At work we have a Volvo tractor (tractor trailer type, not farm) that made several trips to different shops for an intermittent problem of shutting itself off. It was finally traced to a corrosion hole in the top of the fuel filter base. It had caked crud that hid it till the one garage was pressure washing the engine.
   / Start with the simple things - Ford 6000 now running fine #5
My 85 Harley Sportster, which I have owned since new, has been leaking a lot of oil. My wife has been putting potty pads under it that we had left from training the dogs.
Found that the problem was simple, the hose clamp at the bottom of the oil tank had worked loose, but it required some disassembly to get to it. In the process, I discovered that the mounting bracket on the side of the tank that helps support the battery tray had fractured due to vibration (Those who have ridden Sportsters can relate), I will have to get it welded back, get some good snail clamps, do some serious cleanup, then reassemble.
   / Start with the simple things - Ford 6000 now running fine #6
That's the kind of thing which some of us wouldn't figure out until AFTER the expensive fix didn't work. :rolleyes:
Thanks - glad you approve!
Unfortunately, it doesn't always work out that well. For example, I fitted a reinforcing plate to the front of my old Range Rover to stop the radiator from wobbling about. That required just three rivets to hold it to the backing plate. You guessed it - drilled through the plate right into the copper aircon pipe. $200 to repair the pipe and another $220 to replace the direr and regas the system.
Now that ain't bad luck - it is sheer stupidity!
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
