Starlink
/ Starlink #4,691
I'm just testing the $0 rent option for a month, and I've already cancelled the renewal for December. The cost wasn't justifiable for the quality of service, speed varied a LOT for me here in NW Montana. I am getting fiber past my house this spring, so I'll be waiting for that. Currently use a WISP (Wireless) 52/12mbit service that works for our purpose. Wife and I work some days from home if inclement weather.
Did you have any actual issues incurred related to network speed? Or did you just do a bunch of speed tests and determine that speed inconsistency was a "problem"? If a 52Mb/s service currently works well for you I cannot imaging a scenario where Starlink service is any less performant than that. At least unless there were obstructions.
/ Starlink #4,692
But clear view. It is not to be winked at. Clear view is clear view.
Sorry you are having problems. But it's a personal problem. It is not representative.
Oh coverage doesn't seem to be the problem as you see, I was more curious as an IT guy to see what it was about. I tried the $80 Homeowner lite, was ok at 1st then I discovered I got deprioritized traffic. Upgraded to $120/month, was good for a day or two then ended up with not $40 bucks more worth bandwidth averaging 180/20mbit. I cant wait for my 1000x1000Mbit fiber for $99.95 in the spring.
/ Starlink #4,693
Im only going for 400x400 fiber, as thats plenty for my needs. Its like $49/ month including free modem and installing. They already have the underground up to my property line, but not sure if they will be able to get it to my house before snow and frozen ground. There working on some overhead feeds and the main laterals underground right now.
/ Starlink #4,694
How in the world do need that bandwidth at home?
/ Starlink #4,696
I have had Starlink for a few years now. It is faster then my wisp was but it has the same issues with weather issues causing outages and extreme slow downs. Even when a speed test shows a good connection I've had issues with computer and or TV pinwheeling and pausing. I've relocated my antenna 3 times because of so called interference.
I've had nights when it reminded me of dialup, it wasn't a single line of a picture crawling accross the page but I seen partial pictures quite often. Or had to sit and wait for picture to down load.
/ Starlink #4,697
Sorry to hear that you are still having issues. You've mentioned this before, and it makes me wonder what / how your network is configured, and whether there is anything that could be done to help. If you don't mind me asking, are you using the Starlink WiFi directly? When you have downloading issues, have you run speed tests with the Starlink and at speedtest.net to see how different they are (or not)? Is it a major website?
Even in heavy rain here, we haven't seen weather related slowing. We do have occasional outages (usually less than a second, rarely three seconds or so), but those can be seen in the app. We've had a handful of times where the local, and Starlink speeds were high, and something was off getting out of Starlink's network (e.g. not being able to connect to Google.com, or speedtest.com).
For us, the upgrade to Gen 3 made a noticeable improvement in the speeds, and reduced latency, and the WiFi does carry much farther. The only websites that occasionally I have trouble with are not mainstream websites, which makes me suspect that their website is hosted at a site that runs out of capacity.
All the best,
Peter
/ Starlink #4,698
"Always Ready: Upon arrival, your Mini will be on Standby Mode for $5/mo, which includes unlimited low-speed data for backup and emergency messaging."
What do they consider "unlimited low-speed data for backup"?
I'm accustomed to working with 1 or 2 MB down, 0.6 M up.
Heck, this a.m. in Alexandria, Va, with a Cox plan rated at 300 Mbps for about $55/mo I was getting:
/ Starlink #4,699
Standby mode does up to 500K down/up. Latency is the same as normal operation.
/ Starlink #4,700
All the best,
Peter
The internet is not just one thing?!? Nahhh.
2018 Multiquip AR-14 (A60462)
2018 Multiquip...
2017 Infiniti QX60 SUV (A59231)
2017 Infiniti QX60...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Case CX36B (A60462)
Case CX36B (A60462)
