Star head screws
   / Star head screws #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I'm rununing across more and more screws with the star shapes holes in their heads also called torx screws. I often find myself having to drive the screw into the head with a hammer. Are they supposed to fit that tight?
   / Star head screws #2
Get yourself a set of torx bits and save yourself a ton of headaches. they used to be hard to find, but the screws are so common now the bits are available everywhere.
   / Star head screws #3
If you have to drive the Torx driver into the screw, you probably have the wrong size. Either that or poor quality driver set or screw.
   / Star head screws #4
Most of the better screws come with the bit right in the box. Used a few 1000 this years and only had 2 or 3 screws with a head that the bit didn't fit correctly.
   / Star head screws #5
I can't remember having much trouble fitting the torx drivers to the screws.
   / Star head screws #6
If I had my way, I'd never have to use another Phillips head screw again in my life. Torx screws are such a dramatic improvement. I love not having to push the driver into the screw. Try driving 10 Phillips screws into something over your head, or by your ankle, then repeat with torx screws. Night and day. Like others said, you may have the wrong bit size. For general construction screws, T20 and T25 are the most common sizes, and they do look similar.
   / Star head screws #7
Out of a 2 1/2 pound box of galvanized Torx head wood screws, I did find a couple where the galvanize completely filled the Torx hole.
   / Star head screws #8
I'm rununing across more and more screws with the star shapes holes in their heads also called torx screws. I often find myself having to drive the screwdriver into the head with a hammer. Are they supposed to fit that tight?
I've never had that problem out of boxes and boxes of screws. Larger screws take larger torx bits but they usually come in the box of screws. Most drive bit sets also include torx bits in several sizes. I love em over even the square drive screws. in order of preference torx, hex (allen), square drive, phillips then common slotted which should be banned from the face of the earth then phillips drives should be done away with.
   / Star head screws #9
I needed to use some 3-4" screws so got a bunch of torque head screws and of course new bits. What a nightmare using them. Although the torque level was high it seemed to strip out the heads of the screws way to easily.
By contrast, long #3 screws give me the least amount of trouble but are getting hard to find.
   / Star head screws #10
I haven't had that problem with Torx either. A good impact driver sure helps with larger screws. The impact makes driving larger torx screws easy that would likely have been impossible with phillips head screws. I have a DeWalt DCF886 that will drive almost anything I put to it with up to 1500 in/lbs (125 ft/lbs). I've snapped some screws in half or twisted heads off but haven't stripped any torx heads yet. It makes for a nice little impact wrench in tight spaces too.
UNUSED FUTURE QUICK ATTACH 72" CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
Wolverine 74" Quick Attach Bucket (A50515)
Wolverine 74"...
