standard height for cat 1 3 pt hitch
   / standard height for cat 1 3 pt hitch #1
coolhl7
Bronze Member
Panhandle Florida
MF1540HST
is there a STANDARD height for a CUT that one should expect a cat 1 3 pt hitch to raise an implement off the ground? Thanks.
   / standard height for cat 1 3 pt hitch #2
I think all tractors have a wide variation of adjustment. The 3 PT links have various holes for lifting to different heights etc. No set rule. Set them as needed..
Thanks for the reply.
I feel like I dont get enough clearence for my 1000lb bush hog on the back of my 40HP CUT.
I am not sure of which adjustments to make first.
I have 2 holes on my lift rod where it attaches to the lower link.
should I try the higher hole first.
I could also attach my lower links to a lower pin setting on the cutter.
It seems the back wheel is only 6 inches off the ground in transport.
sorry for the newbee questions but I want to start off right.
   / standard height for cat 1 3 pt hitch #4
Call me dumb or uninformed, but what is a CUT? Is it compact utility tractor?
Yes it is.
   / standard height for cat 1 3 pt hitch #6
My ford 3 point will lift a brush hog high enough to walk under to work on... no, I would never walk under but it lifts pretty high.
mark
   / standard height for cat 1 3 pt hitch #7
Depending on the implement, you can get a lot of adjustment just by shortening your top link, or the chain if that is what you are using for something like a rear mower or brush hog. That will get a lot more clearance on the back of the implement.
Don't appologize for questions! That's why most of came here in the first place, to get answers!!!
Brad
2014 Nissan Versa Note Hatchback (A51694)
2014 Nissan Versa...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2013 Mahindra MPOWER 85P 4WD Tractor (A53117)
2013 Mahindra...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2008 Chevrolet Uplander Van (A51694)
2008 Chevrolet...
