Nik
I need your collective expertise. Hooked my B2410 HST to a 4 ft WOODS brushbull rotary cutter this evening. I drove the tractor out of the barn with the cutter about 50 feet to a field of 3 foot grass. Ran smooth. Engaged the PTO at low speed and advanced to rated RPM. After about 25 feet of cutting in low range the tractor started lugging, losing power and ultimately stalling. I disengaged the PTO. Checked all fluid levels and radiater filter. All were normal. Started the tractor again without a problem. It ran fine. However when I engaged the rotary cutter the same thing happenned after going 20 to 30 feet. I restarted the tractor easily and drove back to the barn. The 3 point hitch would lift the cutter as usual. I checked to make sure the parking brake was off and it was. My thought is that the PTO shaft may not be turning easily and placing too much load to the tractor. I checked the oil level in the cutter gearbox. It seems very low. When I unscrew the side drain some thick yellowish oil comes out so it isn't completely empty. This rotary cutter does have a slipclutch but I could not hear it slipping during operation. The cutter is about 2 years old and barn kept. As it is now dark I did not want to disconnect the cutter from the tractor. My small barn has no lights. The tractor had been run this weekend with a finish mowerand worked well. The fuel tank is at least half fuel. What should I check or do next? Thanks for your help.
