Oil & Fuel Stale Stihl gas/oil mix: Can I put it in my Tacoma?
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #1
HillStreet
Veteran Member
Maine
Kubota B2650HST. Kubota Z125S
My Stihl saw is in the shop because of an old fuel problem. I think I will buy and use the pre-mixed stuff you see around now. I have a gallon of fuel/oil mix. Can I just put that into my truck to get rid of it?
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #2
I speculate you will make sensitive fuel control and emission sensors crazy if you do. Engine may shut down and require a dealer service to reset crazed computers.
Others will offer differing speculations.
Never even thought of that. That's a scary proposition.
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #5
I'd burn it in an old truck but not a new one. For only a gallon it would go in my waste oil buckets.
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #6
I would put it in my lawn mower, that is what I do with old gas.
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #7
I have a 2003 ranger that is the recipient of all my old gas. I just make sure I have over a half tank to start.
I would but my mower is a new Kubota Z turn, too early to fool with that. Truck is 2015 so I won't do that now either. I may just burn brush and fire it off--very carefully.
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #9
The oil will kill the catalytic converter and O2 sensors. I can't be specific on the time it will take, but it will happen.
-R
   / Stale Stihl gas/oil mix: Can I put it in my Tacoma? #10
My 1930 Model A will burn just about anything... very forgiving!
1985 International X Con Semi (A50514)
1985 International...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
10' Feed Bunk (A50515)
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
