Stablizer scratches
   / Stablizer scratches #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
Even though I know it is a tractor, when I put down the stablizers, they get scratches from touching sand ,rocks where the stabilizer isn't using pad for support. Is there something I can put to protect them or just touch up the paint occasionally. There is also a fitting that is under stabilizer that could get damaged from rocks, etc. The grease fitting on stabilizer pistons look like they could get dirt as they have no rubber cap on the fittings , near the pads. Thank you for any advice. plowling
   / Stablizer scratches #2
Myself, I would just touch up the paint as needed. Don't worry about the grease zerks. Just clean them off before greasing. Hard to break one unless have direct blow. I have had grease zerks wear off on farm equipment due to contact with dirt/tilling over a long period of time.
2 Engines and Transmission pallet (A50325)
2 Engines and...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
Lot of Nissan Engine and Transmission (A50325)
Lot of Nissan...
