SSQA snowplow mount
   / SSQA snowplow mount #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I'm reading about how a frame mount is preferred over a quick attach mount using the loader arms. Makes sense that loader arms can be damaged. I'd like to hear from anyone who actually bent or damaged loader arms while snowplowing.
   / SSQA snowplow mount #2
I have had my FEL mounted snowplow for four years(do about 2 miles) and have had no problems.
8ft.Curtis(old truck plow) on a L4240 Kubota.
I had a six ft.sub-frame mounted on a L3130 HST Kubota and it worked fine but had limited lift and the loader had to be removed.
The plow has trip springs.
Thanks for the reply. One would think that if mounting a snowplow on the loader arms was really so problematic, others would have chimed in here.
   / SSQA snowplow mount #4
I have a7 1/2 foot Fisher ( old truck plow ) welded to a QA plate. I like it because I can get some down pressure when needed and can stack snow 12 feet in the air.
   / SSQA snowplow mount #5
Been plowing for years with a loader mounted snow plow.
No problems
   / SSQA snowplow mount #6
3rd season with my 7 foot loader mount unit. never any issues. works great
   / SSQA snowplow mount #7
Snow engaging is different from ground engaging as far as load on the frame vs FEL goes
Could it be the slow plowing speeds that prevent loader arm damage?
   / SSQA snowplow mount #9
I have had both scenarios. In my opinion I like the frame mount much better. The swing of the machine with the loader arms and then a plow out front is a pretty wide arc. I have to plow in sone tight places so this is a problem for me. The frame mount keep the plow up close. Also when you have the plow out on the end of the loader arms you'll have a much greater tendency for the front end to get pushed sideways when the plow is angled. The loader arms act as a leaver.
Regards,
Chris
I've never plowed with a tractor snowplow setup so excuse my ignorance. With a plow on the loader arms does the tractor front or tractor rear have more of a tendency to "swing out" due to the longer lever vs. a frame mount?
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
19103 (A51694)
19103 (A51694)
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
