Amvcane
Platinum Member
- Joined
- May 24, 2013
- Messages
- 664
- Location
- NEPA
- Tractor
- 2012 Kioti CK35hst tlb; 1988 JD 420; 1990 JD 322; 1987 JD 332; 1985 JD 318; 2010 JD ProGator 2030A;
Quick question.
I am running hoses for a Meyers plow mounted on a ssqa plate. The cylinders are single action. Do I need to fill the SA cylinders with fluid before hooking up?
If I mount the plow, lift it up and dump the curl so the plow and cylinders are verticle with the connections up, will that help? Or am I way overthinking this? Its my first use of SA cylinders.
Andrew.
Andrew.
