Squeal and 3pt raises when cranking
   / Squeal and 3pt raises when cranking #1
jonree
Summerville, SC
Mitsubishi D1800
I posted this in the Mitsubishi forum but thought I might get a general hydraulics answer here. Bought a Mitsubishi D1800 at an auction, 3pt was not working, no squeal and tractor ran fine but felt like no resistance at the control lever, but I went ahead and replaced the hydraulic oil and cleaned the filter since it was cloudy. Didn't have any resistance and pressure at the control valve so I replaced the pump.
Now the 3pt lifts upon cranking, has pressure at the control valve and a high pitched squeal that sounds like its coming from the suction pipe. The only way to lower the 3pt is unscrewing the control valve until oil is released. The lock lever will not keep it from raising and won't help in lowering.
Any thoughts would be appreciated.
Thanks!
   / Squeal and 3pt raises when cranking #2
Sounds like something is plumbed backwards at the valve or the valve is failed. With the lever fully forward, the lift should stay at the lowest position. The lock on the lever isn't to keep it from raising, it is to keep you from lowering an implement too far down.
Thanks for the reply! Do you think if the lift lever linkage is broken in the up position it could cause this? Thanks!
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
Kubota BX2230D (A47384)
Kubota BX2230D...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
