Square Bale Storage
   / Square Bale Storage #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
We have been storing up to 1200 bales a year in our gravel floor barn and have been fighting the moisture in our bottom two rows. I have built up the gravel to be about 6" above grade and have lined the whole floor with wooden pallets and still the bottom two bales pretty well go to waste. I get free used conveyor belts from work.
My current options:
1) lay rubber conveyor belts on top pallets (can no longer drive into barn)
2) remove pallets and put conveyor belts right on top gravel (ground will become uneven underneath)
3) pour a slab inside existing building (cost too much)
Looking for suggestions.
Thanks.
   / Square Bale Storage #2
You might try a second layer of pallets on top of the one that's already there.
   / Square Bale Storage #3
Is the moisture coming up from below? Perhaps you could line the floor to prevent it coming up with polythene sheet, then pallets on top to let the hay breathe. I presume you know already, the bottom layer at least, needs to go on their side.. if you can leave a very slight gap say 2 inches around at least half the bales, then the air can help take the moisture out better. If you can increase ventilation in any way possible then its worth the effort.
I think the rubber would increase sweating if it is in contact with the bales.
   / Square Bale Storage #4
Agree. 6 mil plastic on gravel; pallets above. Would have been nice if you had put it under the last layer of gravel you put in.
   / Square Bale Storage #5
Ditto what RickB stated.
   / Square Bale Storage #6
How moist is the hay that goes in?
Sounds like needs more ventilation regardless of the ground moisture. Is the ground particularly moist?
What kind of walls to the building, how is it ventilated?
   / Square Bale Storage #7
Hay dried properly then stored doesn't need ventilation. Symptoms of lower layer mold are directly related to ground moisture. The cure is to keep it out, not let it in then try to get it back out.
   / Square Bale Storage #8
We don't know it is properly dried.
My current options:
Thanks.
   / Square Bale Storage #9
If it wasn't properly dried he would be complaining about mold in more than the bottom two rows. Also note this problem is not a one-year deal but over multiple seasons.
Same problem every year. Same cause. One solution; keep moisture from getting in the hay after it is stored.
   / Square Bale Storage #10
Don't mean to hijack, we have a layer of used silage cover under our house, on the ground, with the odd shovel of gravel to keep it tight and quiet, and it has hugely lowered the condensation over winter. Perhaps this would be a cheap source of plastic for the OP
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
