Spring Tooth
   / Spring Tooth #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I have a 6', 3 point hitch, quick hitch compatable, teeth have holes so you can attach sweeps. I will be auction off on Sept 6. in north centrel Kansas. I don't expect it to bring much in this area. If interested in a bid let me know.
DDT
   / Spring Tooth
Pic #2
   / Spring Tooth
Last pic
   / Spring Tooth #4
'scuuuuuuuse meee but what do with it? I'm not much as a dirt farmer, can you tell?
Patrick
   / Spring Tooth #5
It has several names, chisel, vibra-shank cultivator. It looks home made. It is use to break up hard pan caused by the plow in the field. Two type of points are attached to each tooth. Chisel which are about 2 to 3 inch wide and a point on each end and some have a slight twist to flip the soil as it is draged through the field. Wide sweeps look like the chisel only add sweeps looks like wings to extend the area of soil moved by the Chisel.
Wish I had one of those this weekend when I till up part of my yard and the ground was so hard and dry.
Dan L
   / Spring Tooth
It looks home made
It is a factory unit, but it was 21'. I just cut it down to make three- 6' units out of it. it's hard to find small ones with 3 point hitch. The acutioneer thought it would only bring $100 to $200, but that's normal since I got about $300 in it, new iron adds up.
DDT
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
