Spring tooth equals rake?
   / Spring tooth equals rake? #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
Has anyone fabricated a rake using the teeth from old spring tooth harrows? Have two harrows in pieces - that old iron just does not rust away - and my thrifty nature says use them.
   / Spring tooth equals rake? #2
hey,
Go ahead, You can do it!, We all have faith in U...& it'll be fun, why not? If I had the parts & time I'd peck away at it too.
I'm, sure someone will chime in & give U some worthwhile advise...
I bought a Lobster Boat in Winter Harbor a while ago.Nicest little boat you ever work a trap from!..
Good luck, Paul.
Like you name, sounds fishy. /forums/images/graemlins/smile.gif
</font><font color="blue" class="small">( Like you name, sounds fishy.)</font>
Heh...Heh...Took a minute for my dull brain, but then I got it! And...I like it.
Should hav explained further about using spring tooths. What concerned me was the "curl" and width of the teeth. It they are too wide and act more like a blade than a rake...I suppose a wider space inbetween would be called for.
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2022 FORD F-250 SUPER DUTY (A52472)
2022 FORD F-250...
