KanakaRick
and I went to put the backhoe on my 2004 DK50. Everything was working fine last fall when I took it off and put the rear blade on. So I dropped the blade and backed up to the backhoe and hooked up the hydraulics and when I was operating any of the backhoe joysticks, there was slight movement of the associated hydraulic cylinder, but literally milimeters of movement. So I switched the connections and nothing happened. I've got a hydraulic tilt for my rear blade and I hooked it up to the Hydraulic line and when I pulled the lever the tilt worked, so it appears there is some sort of issue in the backhoe. Can anyone enlighten me as to what is going on? I cannot get any of the joysticks to do any sort of movement. I checked the hydraulic fluid and it seems fine. I am perplexed. I've been messing with this over an hour and cannot figure out why it won't operate. Enlighten me someone.
