Spreading Lime with belt trailers and railroad iron
   / Spreading Lime with belt trailers and railroad iron #1
jpbertel1234
JD 2240
I want to order lime and have it delivered in belt trailers. When the trucks towing belt trailers arrive....I will have them drive over ground with belts slowly kicking lime out the back in small windrows up and down the fields. Then I will take a 20 ft. railroad iron and drag the windrows to try and consistantly spread the lime. Has anyone ever done this? and or Does anybody think this would work? I will save 35 $ a ton doing this and will be spreading approx. 500 tons.
Jeff
   / Spreading Lime with belt trailers and railroad iron #2
Maybe do a drag hollow or chain link fence instead. I think the railroad iron would just compact it more then spread evenly
   / Spreading Lime with belt trailers and railroad iron #3
500 ton...? Isn't that like 20 tractor trailer loads. Holy crap..!
   / Spreading Lime with belt trailers and railroad iron #5
I could see considerable problems with that method of application;
1) it would be hard to get a uniform application rate
2) tractor trailers can have a hard time driving in fields,
stuck
deep ruts
3) how would the drivers keep uniform spacing between rows
4) lots of compaction to ground
Spreader trucks with floatation tires are normally the best way to apply, have trailers unload, then load spreader trucks.
Or park trailers and use an auger to load trucks directly.
Good luck
   / Spreading Lime with belt trailers and railroad iron #6
Jeff
It won't spread out evenly that way. You need it spread with a spreader.
   / Spreading Lime with belt trailers and railroad iron #7
   / Spreading Lime with belt trailers and railroad iron #8
Where are you located? That seems like a very high spreading fee. Here in south central IL , the lime is only about $25-30 per ton and that includes hauling AND spreading. Typical rates are 3-4 tons per acre. They dump the lime with semi's, then use a front end loader to load the spreader truck.
I don't think you will get it spread very evenly with your proposed method.
Thank you for your replies.....One other thing I failed to mention is: The lime will be dumped over the top of sod and then disked twice and plowed .....after of course I can successfully spread it.
   / Spreading Lime with belt trailers and railroad iron #10
Another option is to buy a 3pt PTO sead spreader and use that
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
UNUSED FUTURE FT-S13 ELECTRIC MASSAGE CHAIR (A54757)
UNUSED FUTURE...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
