Spreader for my 2305
   / Spreader for my 2305 #1
EasyE
North Carolina
JD 2305
Where can I get a spreader for my 2305? It doesn't "have" to be a JD brand, I just need one for fertilizer and lime on occasion.
   / Spreader for my 2305 #3
EasyE,
I purchased this one from thesmartfarmer.com -- so far I have been nothing but pleased with it:
Cost was $299 plus freight.
If you do go this way, you should cut down the included pto shaft by about 1"
Cheers
JDFANATIC
</font><font color="blue" class="small">( EasyE,
Cheers
JDFANATIC
)</font>
Please explain about the cut down part?
   / Spreader for my 2305 #5
EasyE,
Very simple. The PTo shaft comes in a 2 piece unit so it can telescope as needed to raise, lower and attach. It is also shrouded for safety with a 2 piece plastic shield. All you have to do is remove the plastic shield, separate the two piece shaft, and remove about 1" with a hacksaw. After filing off the burrs, you reassemble the unit. Very simple. Even I can do it. /forums/images/graemlins/tongue.gif The only reason I mention this, is that some forum members have had expensive, and non-warranty crashes with damage to the transaxle. On my 2210, raising the spreader to the top, only lightly collided with my PTO and why take any chances with a very simple adjustment. /forums/images/graemlins/wink.gif
OK I understand now. Thanks.
2007 CATERPILLAR 303.5C CR EXCAVATOR (A51242)
2007 CATERPILLAR...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2012 International 4300 Reefer Truck (A52128)
2012 International...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
