spraying for beetles
   / spraying for beetles #1
Sigarms
Super Member
Mid north west in the state of N.C
F3080
Learned about the Jap beetle last year at new home. Found out about "sevin" as a "cure".
Found some of the beetles out on the trees while weeding two days ago. Last year bought a 3 gallon spayer, using it the last two days.
Couple of questions from experienced people dealing with spaying and using sevin.
Using about 3 oz per gallon, 9 oz for the whole sprayer. Since I now have and idea from last year on what trees these buggers like to go, "pre emptive"
spraying some of thre trees they have not hit yet.
How often do I need to re-apply it or do I?
Is my "mix" about right? (directions for all those trees and mixes, not sure).
Hit the trees these beetles are on, 1/2 hour later, most are dead, do I need to reapply to the tree?
My understanding from last year is to get them before they hatch (?), while they are "spores" (?). Where do you know in the ground to get them? Or do you just do a "shot gun" effect on the land? And when do you start this process?
Debating right now if lay some traps down. Realize that this may bring more, and to lay the traps away from the trees.
Have about a good 4 acres in front of the house, good 40 trees of everything you can imagine growing. Would it be worth while to get a bigger sprayer with a motorized pump sprayer? Only have a pickup truck, no ATV, thinking about putting in back of the pick up truck and just drive around spraying all the trees from the p/u. Is this worthwhile and worth the money, or should I just keep refilling and hiking the property and spray? Thinking about a sprayer from northen tool or some place like that, not sure what to look for.
Any suggestion would be appreciative.
   / spraying for beetles #2
Comes in different concentrations so use the directions on your package. Rain WILL wash it off. Several heavy dews will also. If you have just discovered sevin, be aware it is highly toxic to honeybees as well, and spraying anything that is blossoming or about to creates a significant chance of destroying a hive. They carry it back into the food supply. We use it mostly for ants...sprinkle a little around the hill, they carry it in, it contaminates their food supply, no ants in 3 days or so.
In my experience traps bring them in. They certainly don't seem to reduce the number year to year. Insecticidal soap or oil is a good alternative if you can spray them directly.
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
