Spraying 40' trees
   / Spraying 40' trees #1
tbwamp
Montana
Massey-Ferguson 135
I would like to put together a setup to spray pine trees for the Mountain Pine Beetle up to 40' high; I have 30 wooded acres.
I plan on getting a 50-70 gallon tank to minimize the number of times I have to refill it. Will probably jimmy up some sort of carryall to mount it on my 3 point hitch.
I do have a lot of hills, and won't be able to reach all my trees on my MF 135 tractor without killing myself. So, I would like to attach a good 300 feet of hose to extend the area I can cover.
I'm wondering if it is reasonable to try to do this with a PTO-powered roller pump. Anyone have any ideas?
   / Spraying 40' trees #2
First off- You mentioned you have hills. are there areas where you will be driving on a hill with water ? I am thinking you might want a wagon type in stead of on 3 pt. With water on 3 pt on hills can slosh over to low side offsetting the COG of the tractor causing a flip. building a wagon with tank as low as you can would be better and if wagon does flip, it wont take tractor completely.
Anyway how how can you make a spraying boom ? I was thinking if you had a single spring loaded tapered boom with 2 spray nozzles on top of the boom spraying out to the trees. The spring is for letting boom go down if hit any branches. If you plan on spraying manually on the steeper hills, a hose attached seperately ready on a wind up wheel on tank?
   / Spraying 40' trees #3
I use a pressure washer. Its electric, so I throw on the pto generator, put a 150 gallon horse watering tank in the front bucket, and go to town. No problem reaching the top. Never had a problem with chemicals in the PW either (its a Stihl). But, a roller pump can do the same job if its fed right. If you have a gas PW, then you could haul it around with a lawn mower carrying the tank or a PU truck bed is a nice platform to run from, especially if you have someone else to drive it for you while you spray trees. My PW has enough jiuce to knock the gypy moth worm nests out of any tree around here, too.
What are the specs on your power washer? What lengh of hose are you using, and what kind of wand are you using at the end of it?
Thanks!
Good point about the COG. I wouldn't want to use a boom at all. Just a long hose with a triggered wand at the end.
   / Spraying 40' trees #6
Whatever way you choose wear some kind of mask...do not inhale any of the chemical you spray...be aware of the wind direction. I remember many years ago here in Ga. a landscaper was on the TV news and he was on his death bed and he leaned forward and asked the Doctor if " Paraquat " would be his end...that was the chemical he had been spraying and the wind changed and he breathed it in...and the doc said yes and he died shortly after that...Be careful !
   / Spraying 40' trees #7
Hmmm 30 acres of up to 40' trees? Have you checked into any local crop dusters? Seems like it would be a much easier way to get it done. :D
   / Spraying 40' trees #8
tbwamp
A PTO roller pump should work fine, and a 50 gal tank mounted on your 3 ph will not cause a problem with your tractor (for sure not the MF 135), if kept low and vertical (like a 55 gal drum upright). Also, the hose and nozzle would be similar to those wands used in orchards to spray trees. Getting up 40' shouldn't be a problem if you have the pressure regulator on and crank it up.
And the pressure washer trick might work well too. I only know that the PTO roller pump will do it. :)
I sure like the idea, but...I guess the MPB hasn't gotten to Meridian yet. You have to saturate the trunks, specifically, just getting all the dust on the needles wouldn't do much to the little bastards.
   / Spraying 40' trees #10
We are mostly farm land around here, not a lot of pine trees. That sucks. How often do you have to spray for them? 30 acres sounds like a lot of trees... are you going to use a paintball gun or something to mark them after you spray them so you can keep track?
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
2018 Wacker Neuson RTLX-SC3 Trench Compactor (A44391)
2018 Wacker Neuson...
2011 PHOINIX GLOBAL 42S STATION MANIFOLD TRAILER (A45333)
2011 PHOINIX...
2013 Bobcat T300 Two Speed Compact Track Loader Skid Steer (A42742)
2013 Bobcat T300...
ClubCar Electric Golf Cart (A42744)
ClubCar Electric...
2016 Ford Fusion S Sedan (A44572)
2016 Ford Fusion S...
