sprayer wiring
   / sprayer wiring #1
redhawk
Bronze Member
christiana , pa
Kubota BX2200
hi guys, i'm looking to run wiring for a pull behind sprayer on my bx2200. the b7500 i used to have had a place in the harness in the back of the tractor that made it easy to do.
i've been looking but this doesn't seem to be the case with the bx. do i need to run wiring directly from the battery? or is there another way. thanks in advance to all
kevin
   / sprayer wiring #2
What I do with my sprayer is tie into the tail light wiring, which means I just use the light switch on the dash to turn the sprayer on and off. I have a two-wire trailer hitch connector that I use.
I see that the next tractor I get (JD485 all wheel steer) already has a cigarette-lighter type plug available with a switch to make such attachments easy to use.
   / sprayer wiring #3
I did this last year. There should be two wires under the seat - red & black. One has a male and other female plug-in type connectors on them. You can put the appropriate connectors on the wires from the sprayer and simply plug into those. Although there was a switch on the sprayer already, I wired one into the circuit up by the seat so that I could turn it on and off without having to get off the tractor.
   / sprayer wiring
rlw, that sounds like the setup i had on my b7500, i looked but didn't find that setup. but now that i know it's there i'll do an intensive search. thanks
kevin
   / sprayer wiring
rlw, i found the wire ends tucked up under the fuel tank. many
thanks, kevin
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
7 Shank V Ripper (A52128)
7 Shank V Ripper...
2006 MACK CT (Granite) (A50323)
2006 MACK CT...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
