Spreader Sprayer vs Spreader
   / Sprayer vs Spreader #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I need some advice from the lawn car pros on the list. If I'm looking for just lawn care use, are spray fertilizers generally better than spreading dry fertilizers and weed killers? I'd be mounting the sprayer on a 3ph or a box hitch on the 3ph.
I would be spraying my 1.5 acre plus a few neighbors lots too.
   / Sprayer vs Spreader #2
Someone will chime in with this so I might as well get it done right from the get-go. You can apply pesticides and fertilizer on your own property, so long as they're not restricted use products without any certification. When you take the show off your property, you need state certification for pesticide use in all states, and certification to spread liquid or granular fertilizers in MOST states. Most lawn care companies that handle those jobs are certified. They "police" the guys who violate the laws to protect their own interests. It can be VERY expensive if you get caught. This applies to "for hire" or just for "free gratis" off your own property. And this doesn't even begin to tackle the issue of restricted use chemicals, of which there are many. One of the initial requirements for certification is proof of insurance for pesticide application. That requires proper training, as well as ALL the required equipment (wind meters, spill clean-up equipment and supplies, proper respirators, protective clothing, record keeping, and knowledge of the business in general)
You can't even purchase restricted use products without proper certification.
That said, liquid fertilizers are easier to handle and spray IF you have the proper equipment. For small scale operations, the change-over from one type fertilizer to another is substancially easier with dry granular though. Initial start-up investment is considerable less expensive for dry too. For smaller applications, a drop spreader is more accurate and less waste than a broadcast spreader in some cases.
For the record, pesticides are ANYTHING chemical that kills ANYTHING when applied, be it insects, weeds, disease, ect.
It's far more involved than just buying a spreader or sprayer unless you like to pay hefty fines. Farmers have to comply, lawn care companies have to comply, golf courses have to comply, even homeowners must comply if they use any restricted use products.
...and the rules keep getting tougher and tougher as time goes by as you might imagine.
Basically all the neighbors all do the work ourselves. I could always let the neighbor drive the tractor and then I'd be off the hook. We all aerate, fertilize and weed at the same time. We just did a 'team' effort on mulch and spread 40+ yards of mulch. Too BX's dumping and about 15 raking level. We finished in a day.
I figure what's the difference if I use Scott step 1 or just a liquid fertilizer.
   / Sprayer vs Spreader #4
Get a sprayer. It works faster and more evenly than granular. There are plenty of non-restricted use products available that will do everything you want to do as a homeowner. Depending on what herbicide you choose, you can mix in liquid fetrilizer and do a weed & feed aplication. Pick the brain of the your expert at your local Southern States store and I think you'll get all the info you need. I know I did. My guys are a tresure trove of info and experience.
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
DYNAPAC DBL DRUM ROLLER (A52707)
DYNAPAC DBL DRUM...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
