Sprayer Pump Winterization and Storage
   / Sprayer Pump Winterization and Storage #1
workinonit
Elite Member
Scranton, SC
JD 5090E
What does everyone do to store and/or winterize their sprayer pumps? Obviously some ammonia or cleaner needs to be used to neutralize but do you spry some type of oil in them or anti-freeze?
   / Sprayer Pump Winterization and Storage #2
I've always used RV antifreeze in my sprayer trailer and pressure washer.
One year I forgot to do it in the pressure washer. It burst. ;)
   / Sprayer Pump Winterization and Storage #3
Automotive antifreeze in my pressure washer, to prevent the corrosion that killed my first one.
No idea about flushing a sprayer first.
   / Sprayer Pump Winterization and Storage #4
Cleaning 1 gallon ammonia to 100 gallon water. Agitate let sit overnight. Run through sprayer following day then run clean water through. This is not the complete set of instructions I do.
To winterize I put several gallons of rv antifreeze in and run it through the system and leave it.
   / Sprayer Pump Winterization and Storage #5
And i remove the filter bowl and leave it on the shelf. Learned this thru broken bowl 1 year.
   / Sprayer Pump Winterization and Storage #6
I’ve used RV antifreeze, which reminds me I need to do mine.
   / Sprayer Pump Winterization and Storage #7
RV antifreeze in mine also. No corrosion problems.
   / Sprayer Pump Winterization and Storage #8
Ditto here on my pressure washer, blow it out with compressed air and fill it with RV antifreeze which, I might add, has gone up almost double what it was a year ago.
Since we can't get good gas here any more, I also drain the fuel tank and run the carb dry.
   / Sprayer Pump Winterization and Storage #9
I guess I've just been lucky so far?
I just drain mine at the end of the season and leave the input hose loose to dangle off the end of the pump housing.
Now you guys are making me paranoid. Lol.
   / Sprayer Pump Winterization and Storage #10
I do my best to drain everything and disconnect the hoses, but then I bring the actual PTO pump into the basement where it can't freeze. Pumps have gotten crazy expensive.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
