Sprayer Sprayer Problem
   / Sprayer Problem #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I sprayed some Roundup in my Fimco sprayer yesterday. When I was finished I ran down the road a couple hundred yards to spray the last of the Roundup prior to cleaning the sprayer. When I filled it up with water for the cleanup up, it wouldn't spray. I accidentally ran it a little on empty when finishing up. Do you think I may have damaged the PTO pump? Does it possibly just need priming? What is the best way to prime it to get flow again?
   / Sprayer Problem #2
Check your tank strainer, if you have one. I pulled a jug cap seal out of my neighbor's rig earlier this week. Same conditions you are describing.
Running it dry is a no-no, but if it was real brief you probably didn't hurt anything. I am guessing you have some kind of obstruction or valve problem
   / Sprayer Problem #3
I would break down and clean all of the screens/filters. Roundup will really gunk things up if you don't clean thoroughly each time you use it. If not that, then your roller pump could be toast ... but I'll bet you'll find all kinds of clogs in the filters if you look.
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 John Deere TS Gator (A50121)
2021 John Deere TS...
2017 Freightliner M2 106 24ft Box Truck (A50323)
2017 Freightliner...
2012 Honda Civic Coupe (A50324)
2012 Honda Civic...
