Sprayer maintenance
   / Sprayer maintenance #1
crowbar032
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
I inherited a sprayer that was used to spray tobacco. I've repurposed it to spray weeds in my hayfields. Every single time I go to use the thing, I spend more time fussing with the nozzles than I do spraying. Dirt dobbers, various bugs, and sediment seem to multiply and clog everything. I've seen sprayers much larger than mine, and I can't imagine a corn or bean farmer having the time or inclination to take apart a 30 plus foot sprayer every use. What am I missing? What does normal nozzle maintenance look like?
   / Sprayer maintenance #2
Put a dab of grease over the nozzle ends. When you use the sprayer the next time the fluid should wash the grease off.
If you have a sediment problem, it means your not getting the tank and lines clean when you clean up the sprayer when your done spraying.
I'll try the grease trick, thanks. I guess I'll have to work on my cleanup-up game for the sediment. Thanks for the reply.
   / Sprayer maintenance #4
I have had issues as well. After doing some research and lurking on another site for farming only, I have changed my chemical program including equipment.
This is what I do-
Use clean water. I have community water that has sediment (sand) that can clog small tips. I use a screened hose washer that seems to help. May have to use a small screen to strain water, so far not needed. T prevent foaming, the inlet line goes to the bottom of the tank.
Mix chemicals according to label!!! Most require at least 1/2 of water before adding chemicals. Last half of water added slowly as tank is thoroughly mixed by bypass valve.
If multiple chemicals are used, mixing order is crucial as some will clump up and plug everything unless mixed in correct order.
Use a pump that is Roundup resistant, cheap pumps will corrode from glysophate and chunks will break off. The pump I use came from Shoup for $350. A good pump and bypass makes the system work to spray correct pressure, crucial to appling correct amount of chemical. Some stuff is pricey as well as dangerous, I only spray what the label says as far as amount per acre.
I use about a cup of Dawn in each 150 gal load to help in cleaning the lines and tips from atrazine, 24D, etc. It also keeps gunk from sticking to lines, valves, elbows, etc. Cheap stuff works but Dawn is the best.
I always clean the filter. I have rebuilt my system several times, what works best is filter after pump just before the manifold to catch any pump parts. I may add more filters before the tips.
I use a Sprayer Rinse ball mounted at the top of the tank that a hose can connect to for rinsing with clean water. After about 25 gal has gone through the ball, a hose from the pressure line connects to the ball to second rinse. This is usually 50 gals of clean water with tank cleaner that is ran through the pump and rinse ball before running through all the tips. This is when any tip that has issues will be evident. If a tip burps once, it may clog next time.
I have a broadcast nozzle, 4 row drop, 3in wiper and a 12 ft bar with overlapping tips. I use the broadcast nozzle for burndown and spraying when crop (Corn) is small prior to spreading N. After applying granular Urea (N), I will spray Roundup/Atrazine through the drops when the corn is almost too tall to get the tractor over without damaging the plants. Once that is done, I cant get back in the field with a tractor. I have 2 shots to get rid of grass and weeds if the crop is going to make. I used the wipe pipe to deal with a resistant Pigweed problem (Gramoxene, bad stuff!)
Every step is crucial to make my herbicide program work. Anytime there is a issue, I usually find the problem is something I did or did not do correctly.
Hope this helps, nothing worse than having issues that don't seem to get better with time.
Good Luck!
   / Sprayer maintenance #5
This is what I do-
Good Luck!
Good stuff
Thanks for the great write up!
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2011 FREIGHTLINER CASCADIA (A52472)
2011 FREIGHTLINER...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
