Sprayer for use with Yamaha Rhino
   / Sprayer for use with Yamaha Rhino #1
schoolsout
Veteran Member
Awendaw, SC
Massey Ferguson 1533
I've been looking at this one, but will not need the width it provides all the time. I guess my question is does the boom have to be "fully" deployed/opened or can it be modified to have arms swept back some so as to not get the full 140" coverage Fimco claims?
http://www.fimcoindustries.com/ATV-25-700.html
Anyone use this one with a Rhino? I'm not even sure the tank will fit in the bed, so I'll definitely be measuring dimensions.
Planning to spray food plots for deer and maybe through some of the thinned out pines and ultimately, the road we make going through some of the thicker pines.
   / Sprayer for use with Yamaha Rhino #2
FIMCO 25 Gallon Standard ATV Sprayers
I can only tell you that my sprayer that I use(300gal.tractor sprayer) its either you have the boom out or in.It does have 3 valves so you can run each section. I would suggest that a boomless sprayer maybe the way you wonna go for small acres,the only down fall to them is if its alittle windy they tend to drift more. If you wonna spray 30ft to 10ft its just an easy tip change out(2min.),easier to go in and out trees(just watch what you are spraying under those tress,the pine needles should take care of that or have a wand for spot spraying). A 25gal.sprayer fits in my Artic Prowler with room to spare
Thanks!
Haven't bought one yet as they are opening a TSC a few miles up the road from the house and hoping a grand opening sale will occur...That and haven't had the need for one quite yet.
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
2008 Volvo XC90 Multipurpose Vehicle (A51694)
2008 Volvo XC90...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
