Spool Valve Help Required
   / Spool Valve Help Required #1
certaindeath
Scotland
Massey Ferguson 135
Hi All,
Looking for a little help with my hydraulics on my Mconnell Backhoe.
The unit has a 3 spool valve block for controlling bucket, and to arm rams. There was then a separate single valve for controlling the slewing rams. This slewing valve failed so I bought a spring return spool valve to replace it.
I hooked it up basically teeing into the flow and return connections for the 3 way valve. When I started up the hydraulics I had no response from any of the rams when moving the valve handles. I eventually removed the new valve connections and checked the 3 way valve was operational on its own and it is.
I then realised that both these valves are open centre so I was effectively pumping oil both ways into my new spool valve. My question is how can I get around this and get both valves working off the same flow and return lines.
Can I take the return from the 3 valve block and use it to feed the flow of the single valve? Or could I fit non return valves to both the return lines of both valves before the tee together so that the oil can't flow back up to the other valve?
Any help would be most appreciated. Trying to get the darn thing working so I can start digging up my drainage.
Ian
   / Spool Valve Help Required #2
Welcome to TBN
Open center control valves must be attached in series but definitely not teed into hyd system.
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
