Splitting the G174 Part II: 7 Rules for the Complete Idiot
   / Splitting the G174 Part II: 7 Rules for the Complete Idiot #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
The second day of the project has provided a series of lessons:
1. When you have bolted everything back together and you are all ready to do the triumphant drive around the yard in your recently-repaired tractor, the battery will be dead.
2. If the hydraulic pump makes a horrible noise when the engine starts up, do not panic. It is air in the system. If it continues to make an unpleasant noise while running, check the auxiliary levers in case one is stuck.
3. Spring pins require a wire run through them with the ends brought back and twisted together outside the shaft. If you do not have any wire, go no further on the project until you have some.
4. In the drive tunnel of a compact tractor there is not enough space for a pair of pliers to twist two strands of wire if the front drive shaft is in the way. It must be removed again. See rule # 1.
5. Count the items left over in the parts tray. If there is a remaining spring pin, it came from somewhere. Find the universal joint with the missing pin before driving the tractor a mile into the woods on a test run.
6. A loud clunking noise does not necessarily mean disaster. If the front drive shaft universal has a missing pin, it will eventually come loose when the tractor is running in 4WD. The same rig seemed willing enough to idle along in 2WD at 4 mph on the return run to the garage, though.
7. Rod's rule of 30: if you think you have made all of the mistakes possible in the installation of spring pins, you will discover one more. In this case I carefully pinned the universal joint just PAST the end of the drive shaft. Hey, it was dark in the hole. From now on I shall look at the inside of the universal joint for the end of the drive shaft before pinning it.
8. Replacing a spline boss is a lot like setting your hair on fire and putting it out with a hammer. If feels so good when you have finished.
   / Splitting the G174 Part II: 7 Rules for the Complete Idiot #2
And people wonder why mechanics are so expensive :shocked: Oh and to add to the list:
9. When finished and it appears as if it actually works and was done properly, crack open your favority beverage and enjoy while the moment lasts as it will soon change :)
   / Splitting the G174 Part II: 7 Rules for the Complete Idiot #3
I put my B26 backhoe back together. Yesterday I suddenly found one of the joysticks to have a lot of slack movement. As I was removing the cover, the head of a small 6mm bolt fell out so I knew it had broken off somewhere. Got the cover off, found the little culprit which was a small triangular plate that the joystick was mounted to the valves with. One out of 3 bolts had snapped off the ball joints on the control valves. Got out my wrenched to disassemble the whole joystick so I could get to the almost flush bolts. I did manage to get an angular hole drilled in the bolt ( couldn't get it to drill straight due to much interference. Little bolt did come out pretty easy with a #2 easy-out. This morning went to a nearby hardware store and luckily found all my bolts (lost one 8mm when if fell and couldn't find it. The bolts didn't have any stamping to determine grade but the store had some grade 8.8 which is what I used to replace the old ones with. About an hours work to reassemble everything, then fill in the root hole I was working on when it broke. Sure glad that broken bolt came out easy otherwise it would have been a parts order involved to get a new swivel arm.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
