Splitting Large Logs
   / Splitting Large Logs #1
JimMorrissey
Veteran Member
Southern Maine (now)
'05/'06 L39 TLB
I had a huge ash felled this past winter and I've got 90% of it bucked up. Most pieces look manageable, but the base is massive. I've got rounds that are easy 48" diameter. My question is how am I going to split these logs into manageable pieces? I don't think a little rental log splitter with the 5ph honda engine is not going to do the trick, but maybe.....Any ideas?
   / Splitting Large Logs #2
Some people use powder to blow them apart /forums/images/graemlins/laugh.gif
Others just buy a few splitting wedges and go to town with the sledge.
Other grab the chainsaw and rip one side, then drive the wedge in from the side.
We used to prop them up onto the splitter with the other tractor bucket... Good way to get hurt looking back at it!
   / Splitting Large Logs #3
I saw some professional tree trimmers take down some huge trees. The saw must have had a 4 foot bar on it and they quartered the pieces with a saw so they were manageable and we split them the rest of the way with a 20 ton vertical splitter from Harbor Freight.
   / Splitting Large Logs #4
You will be surprised at the power of them little log splitters. Buddy of mine has one that can tip to vertical and it has split some large oak (3 to 4 ft dia) that weight about 500lbs a piece. His has a single cylinder 5 or 6 horse Briggs motor. The hardest part is getting the rounds into position, just take small bites and keep turning.
Dave
Slow that's a good idea....I could cut down one side then split with wedges and a sledge. I will try the splitter first and look around for the biggest one I can find. I plan to screw a big lag ring into the log and lift them into positon with my backhoe.
   / Splitting Large Logs #7
I've split some 42's with a vertical rental unit. My rounds were many many years old and bone dry, but not at all rotten, fairly straight grained fir/pine. I don't know if they would have popped with twisted grain ...
   / Splitting Large Logs #8
Our 13hp Honda with a 5" Prince Hydraulic Ram running off a two stage Barnes hydraulic pump puts out 30 tons, not much can withstand that. Of course, first you have to be able to load the trunk onto the splitter to begin with though. So far, our splitter has successfully split everything that two men could lift to load on to it. /forums/images/graemlins/cool.gif
Sky, I don't have access to such a beast. I'm going to lift them onto the splitter with my hoe and a lag ring (chain them on). I just hope I can find a splitter as beastly as yours. Figures you'd have a two stage super charged splittler capable of crushing steel /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Brew, Yeah that's the problem, twisted grain. That'll put a stop to a little splitter right quick.
Hey, I used to live in Truckee....skied Squaw many many fine days. Drank a lot of beer in the valley too /forums/images/graemlins/smile.gif
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
