Splitting a tractor
   / Splitting a tractor #1
futch
Heya
I have a general question about splitting a tractor.
My B7100 HST-E transmission is squealling . I'm on a budget and need to decide if I can do the diagnosis/repair or if I should seek a professional/dealer to do it.
I have a fair bit DIY experience, and the idea of splitting my tractor doesnt bother me. What concerns me tho, is finding out I need specialty tools mid-way which would drive up the expense.
Does anyone have experience splitting their own Kubota in half? Is it a straightforward process of unbolting until you get to the middle, then going in reverse for re-assembly? Are any specialty tools required? Does a hydro static transmission present re-assembly difficulties (alignment/calibration etc) ?
Many thanks
F
   / Splitting a tractor #2
I would look at other options before splitting it. I would change oil and filters and make sure some screens are not stopped up. I would be sure to use kubota filters and oil. As far as splitting the tractor if it comes to that I would let a pro tackle it.
   / Splitting a tractor #3
If the problem still exists after fluids and filters, get a service manual, take a look at the job and then consult your local dealer mechanic on the symptoms and they may shed some light on the potential problem.
Once you have this info if you still want/need to split your tractor then you should prepare by removing all the sheet metal, tanks, wiring and hoses - also its recommended to mark each of the mating wires/hoses with some tags and numbering scheme like 1W=1W for wire or 1H for hose and so on because when you are putting it back together in two-three weeks this eliminates "memory issues" :)
After you have it stripped down to the basic elements evaluate the mounting holes that could be used for bolt on supports and build some supports and bolt these on to support he two halves - ideally both (or at least one) of these would be on rollers to move this section around. Once these are in place then start loosening the bolts at the clutch/motor split point. It may be different for each model but generally units split at the clutch.
Once you have the bolts loosened and a 1/4-1/2 gap between the two make sure your supports are working and one end isn't going to tip to the sky once disconnected..
I used to split IH farm tractors - its not rocket science but you need to have the right setup to start or you will face issues trying to realign the parts on the reassembly so planning and preparation are key.. Read the service manual too!
Good Luck
Carl - thank you so much for the indepth reply and insight. tomorrow night i'll sump the transmission, replace filter and clean the screens. fingers crossed but the way the trans went out, i think it's a shot in the dark ;-)
thanks again
f
   / Splitting a tractor #5
Lots of good advice from Carl. Think safety! I split my B7100 and reassembled without any unique tools. Clutch alignment can be done without "the" alignment tool. An engine crane would have been handy to roll the two halves apart safely. I found that the I&T manual answered all my questions.
   / Splitting a tractor #6
I split my B7100 HST this spring. I thought I needed to replace the throwout bearing, but my problem turned out to be the pilot bearing. The tractor had to be split to replace either one, so I didn't waste any effort. It was really pretty easy. I put a jack under the back half and an overhead chain hooked to the engine lift eyes on the front. Then just unhook the hydraulic line to the pump on the right side, the return line underneath the tractor on the left, disconnect the throttle, decompression cable, fuel line, electrical wires to the dynamo, lights and the starter and then unbolt the bell housing from the engine. There may be a few more small items I don't recall. I did not take the fuel tank off or remove the hood. Mine is a 4WD, so I had to disconnect the front drive shaft.
My concern, however, is that this does not get you into the transmission. You would probably have much more work to get to that. I would want a pretty good idea of what I was looking for before I tore into it too much.
I spent a week on mine, but most of the time was waiting and running back and forth to the dealer for parts. For my throwout bearing and pilot bearing, if I had the parts on hand it could easily be done in less than a day.
My problem was a 'rumbling' sound when I pushed on the clutch. It worked fine otherwise. Your problem sounds different.
Good luck!
   / Splitting a tractor #7
Heya
Is there any problem other than a squeal? HST squeal is common.
Mine squealed, but more importantly, it had very weak drive power. Cleaning the metal mesh screens solved that. It still screams a bit but it would take a major, expensive, and probably unnecessary, HST tranny rebuild to fix that.
Thanks for the link Egon :)
Well it looks like a split is unavoidable.. Today I replaced the transmission oil/filter. No improvement.
To summarise my other post; drive gear in neutral, dropped the PTO in, heard a pop then a squeal coming from the transmission. Squeal is not there with the clutch pressed. Noise is coming specifically from the housing between the propellor shaft coupling and the dip stick. That is, right under the oil filter (hydro pump?) Sounds like dry metal rubbing.
My question is; can the split be done at the transmission instead of the clutch bell housing? There seems to be a 'split' point there as well and thats where my problem is. I'm hoping I can disconnect the propellor shaft, other rods and split at the transmission.
Tig - good to know. I walked into the Kubota dealer today and a large tractor was split in 2. Front end on jackstands, rear end on a hydraulic floor jack. This will probably be my course of action.
LC7100 - GREAT info. The noise is easy to pinpoint. I think it's shaft#2 which connects to the propellor shaft. I've eyballed all the bits I need to disconnect. Thanks to the inventor of cotter-pins :)
alchemysa - just the squeal. Starts as soon as i release the clutch pedal. It's loud and one of those noises you know can't be good. :eek: Does a total rebuild require all parts changed or just the bad ones replaced and the rest cleaned up? I ask because Kubota come across a little fussy in their literature with 'precision' made components. I used to have a 40+ year old David Brown in Australia and it was just a matter of changing what you needed.
Thanks again to everyone and their replies. Some of the big names chiming in and I appreciate that ! I've got the book on order but that will take a week. It's the rainy season in Florida and I need to get my girl up and running before the grass grows above me!
F
   / Splitting a tractor #10
Fortunately it doesnt really sound like a HST problem then. HST's usually dont squeal til you press the pedal. (In my limited experience). As for the cost of a total HST rebuild, I wouldnt know. I never got that far. But exchange/rebuilt units seemed to be reasonably commonly available as I recall. So I guess that means parts are available as needed.
2430 (A51248)
2430 (A51248)
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
1999 LinkBelt HTC8650 50 Ton Crane Boom Truck (A53117)
1999 LinkBelt...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
